Programming
Hello brothers !! im sorry in advance this post is not directly related to an issue occured in dynamo or package . I worked well on dynamo nodes but now i need to learn coding for dynamo but some suggested me to learn python and others C sharp . Which one should i go for if i wanna learn coding for dynamo . Your help will be much appreciated
posted this here in this group because i already took a lot of help from this group in dynamo and its reliable
LinkedIn Learning has a good python for Dynamo course. I know a little python and find it useful. The Revit API is written in C# so I think it is useful to know both.
if you want to learn coding for dynamo, then you should learn python or ironpython. But if you want to learn revit plugin, then C# should be your choice. Either way, learning either or both is still beneficial to you
