I wish to read & set the Datum of a ProfileView, so its the level range lower and upper. Im familiar with Dynamo and have just recently posted a query which required python, as I believe to solve this requires the same. Im complete novice and came up with this -
profileView = IN[0]
Datum = []
for pv in profileView:
profile_view = t.GetObject(profile_view_id, OpenMode.ForWrite, True)
Profile_View_Name = profile_view.Name
Datum = profile_view.ElevationMin
# Commit before end transaction
#t.Commit()
#pass
OUT = Datum
I suppose Im looking for something I can work from to understand the syntax of it all. Not a lot online for civil3D python
hi
try this
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from System.Collections.Generic import Dictionary
cdoc = CivilApplication.ActiveDocument
def get_profileView_info(profileViews):
global adoc
global cdoc
output = []
if not profileViews:
return
if not isinstance(profileViews, list):
profileViews = [profileViews]
with adoc.LockDocument():
with adoc.Database as db:
for profileView in profileViews:
profileViewId = profileView.InternalObjectId
obj = t.GetObject(profileViewId, OpenMode.ForRead)
if isinstance(obj,ProfileView):
Profile_View_Name = obj.Name
Datum = obj.ElevationMin
output.append([Profile_View_Name,Datum])
t.Commit()
return output
OUT = get_profileView_info(IN[0])
That worked ! Thanks very much, another helping hand from yourself. Much appreciated. I will now look at how to set this value based on your code, helps the learning process.
There were a few errors with spacing/indents and it took some messing about with tab key but got there in the end
