I am new to the Dynamo world and have found a lot of great advice on here.
I have created profiles for multiple alignments and making it so I can switch between multiple or selecting certain alignments. The problem I am having after I save it and try to run on Dynamo Player. The Profile View Station Elevation Label Styles and Marker Styles, after I attempt to run it, do not quite work. When I reopen the Dynamo to check them, they have two outputs and give an error. Any thoughts to address this?
Thanks!
This Dynamo may be a little crude as I am learning the ropes of what it can do.
Hi @nathan.dick,
Which version of Civil 3D are you using? And also, which version of Camber do you have downloaded?
13.2.3893.0 Civil 3D 2020.6
Camber v1.0.1
Thanks. I previously noticed this issue when using Civil 3D 2020 and Camber v1.0.0. The intent was to have it fixed in v1.0.1, but apparently I didn’t test thoroughly enough. I’ll take a closer look and try to have a fix as soon as I’m able.
Sorry for the inconvenience. Thanks for reporting!
Here’s the issue on GitHub for tracking purposes.
@nathan.dick this should be fixed in Camber v2.0.0.
It works great now! Thanks for the work you are doing!
