Profile.CreateOffsetProfileBySlope() in python node keeps crashing
If anyone can assist with this python code I am trying to run the .net api function Profile.CreateOffsetProfileBySlope() from a python node.
I am trying to test if its possible to create an offset alignment and offset profile and keep the dynamic mode for these as per GUI tools in order to preserve desiign intent.
I have a test dwg I am uploading where I am trying GUI workflows for creating Offset Alignments and Offset Profiles and also comparing with doing same in Dynamo and comparing results to see if its possible to get dynamic mode between alignments and profiles?
Please if any experts have the knowledge can you advise if this cannot be done at this time and whether future versions will allow?
Also would be interested in any workarounds for this in multi team project environments where design will go through different stages and be worked on by many individuals mostly using GUI tools, but if a consistent dynamo philosphy to tackle this has been concieved already ??
Anyways here is my dynamo graph and code:
Here is an image of the dynamo graph:
offset_profiles_test.dyn (43.6 KB)
offset_profiles_test.dwg (962.5 KB)
Here is the python node code
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
# Input variables from Dynamo
profileName = IN[0]  # Name for the new offset profile
offsetAlignmentName = IN[1]  # Name of the existing offset alignment
styleName = IN[2]  # Profile style name
slope = IN[3]  # Slope for the offset profile
editor = adoc.Editor
with adoc.LockDocument():
    with adoc.Database as db:
            # Create the offset profile by slope
            offset_profile_id = Profile.CreateOffsetProfileBySlope(
            profileName,
            offsetAlignmentName,
            styleName,
            slope
            # Commit before end transaction
            t.Commit()
            pass
OUT = offset_profile_id
keep getting error No Method matches given arguments OnExit:(<class 'Autodesk.AuoCAD.ApllicationServices.DocumentLock…and unhandled exception then it bombs CAD!
Any help appreciated
cjm
Try this:
import sys
clr.AddReference('Civil3DNodes')
# Import references for Dynamo for Civil 3D
from Autodesk.Civil.DynamoNodes import Alignment as DynAlignment
civdoc = CivilApplication.ActiveDocument
parentprofilein = IN[0]           #profile
offsetalignmentname = IN [1]        #offsetalignment name, str
offsetprofilestyle = IN[2]        #style, str
slope = IN[3]                     #slope, double
result = []
def cmoalignments(parentprofilein,offsetalignmentname,offsetprofilestyle,slope):
	global adoc
	global editor
	global civdoc
	try:
					slopepercent = slope/100
					parentprofileId = parentprofilein.InternalObjectId
					parentprofile = t.GetObject(parentprofileId, OpenMode.ForRead)
					offsetprofile = parentprofile.CreateOffsetProfileBySlope(offsetalignmentname,offsetalignmentname,offsetprofilestyle,slopepercent)
					t.Commit()
	except Exception() as ex:
		result.append(ex.message)
	return result
OUT = cmoalignments(parentprofilein,offsetalignmentname,offsetprofilestyle,slope)
Hi Kovacsv ,
Thanks for your assistance with this, unfortunatley it is still crashing, I am uploading a screenshot of warning message and the crash dump.txt Not sure If you have any ideas?
Regards,
cjm
crash_dump.txt (98.6 KB)
Try switching to Ironpython 2.7. If you don’t have it, you can download it as a package.
It works for me
Hi Kovacsv,
Very Interesting… Thankyou so much for this, I think it is great we can create offset profiles and maintain the objects dynamic mode in c3d!
I have posted another thread discussing the lack of this functionality and how it impacts on complex workflows, this is obviusly a good hack until we get support for it to work in cpython moving forward.
Any tips how you retro installed Iron Python in the latest dynamo versions??
Regards,
cjm
sorry yes you said you can download as a package, my bad, I found it now, cheers
Hi @cjm,
There is an issue in your code that will cause it to fail regardless of which version of the Python engine is used.
offset_profile_id = Profile.CreateOffsetProfileBySlope(profileName, offsetAlignmentName, styleName, slope)
This API call is an instance method, which means that it must be called using the object ID of the parent profile. You can see this in the API documentation:
In your code, you are attempting to call the method as if it were a static method. You can see the difference in the sample from @kovacsv:
Hi @zachri.jensen,
Thankyou for your assistance. Yes I noticed this after @kovacsv sent me his code, but even after I have modified my original It still crashes.
Here is message:
Here is Code:
import sys
# .net api inputs for creating offset profile
parentprofilein = IN[0]  # profile
offsetalignmentname = IN[1]  # offsetalignment name, str
offsetprofilestyle = IN[2]  # style, str
slope = IN[3]  # slope, double
            parentprofile = t.GetObject(parentprofileId,OpenMode.ForRead)
            OffsetProfName = offsetalignmentname+"dynProf"
            offsetprofile = parentprofile.CreateOffsetProfileBySlope(OffsetProfName,offsetalignmentname,offsetprofilestyle,slopepercent)
            t.Commit()
            pass
OUT = parentprofileId
Any further help appreciated.
Regards,
cjm
Thankyou @hosneyalaa
I think it would be better if we could get a cpython solution here moving forward?
not sure if it’s just me, but I have had similar issues trying to get other api code to work in cpython.
it can be discouraging for those of us who spend most of their time as designers and just dip in and out of coding, when there is available time.
It would be great to expand the examples of working code using cpython, I have done c# coding and yes it’s great and provides more robust solutions, but if you are a real scripter, someone who just tinkers now and then to get solutions to automate workflows, then python is the fastest way, to prototype if we have templates for working code, otherwise you can waste alot of valuable time.
Anyways excuse my moaning :slight_smile: I think you all understand my point of view.
cjm
Can you update the script to take List input? right now it only takes a single input. I have so many alignments.
