hello to all
I’m trying to use the node archilab_Cell Style Settings and archilab_Schedule Title Appearance, in Dynamo it doesn’t give me errors but it doesn’t change the aspect of the schedule in Revit, any idea?
I work with Revit 2019.2 and Dynamo 2.0.2
thanks!
Have a look at this page: http://archi-lab.net/downloads/revitdynamo/
It has an example of how to use that node. One thing that you are doing wrong is that you are setting Borders with True/False. These inputs accept Line Style not a Boolean.
Hello Konrad
thanks for your answer
I was already looking at the instructions on the website … but that point was gone
if I change the setting of Borders the node works halfway, the height of the text is modified but it puts a measure that is not the same one that I choose (4)
this is the result:
Is there any way to also modify the style of the cells of the titles of the parameters of the table? , only the header is modified
Is there a node that extracts styles from an existing table?
to copy them …
thanks!
Font size set to 4 would be relatively small:
I think the range is 1-16 so 4 is small. Use a larger number to make it larger.
