So, I’m trying to do a routine that:
Take my current view
Take the selected views
Make the Crop View of the selected views change and be the same as the Crop View of the current views.
But I’m having trouble making two things work: -
the Collect.CurrentSelection node is apparently not refreshing itself without changing the toggle.
I don’t know why, but the View.SetCropBox node, even with the Inputs working correctly, does not modify the SetCropBox.
These blue lines began to appear in the Crop format that I ran the routine in other views, but I was not even able to select them to understand what it is.
I tried with several other nodes and simpler crop formats too but I always get the same results:
Document.ActiveView
