View3d.SetSectionBox and View.SetCropBox
“I am facing an issue when using the RhythmForDynamo package with Revit 2024, specifically as follows:
View3d.SetSectionBox and View.SetCropBox have been removed in the latest version.
I uninstalled the latest version and installed an older package to use View3d.SetSectionBox and View.SetCropBox, but they don’t create section boxes and crop boxes like in Revit 2023 or earlier.
Has anyone encountered a similar issue as me, and if so, how did you resolve it? I would really appreciate any advice! Thank you very much!”
Gavin replied the correct answer. Please use the latest version of rhythm as I cannot and will not support an older version because you wanted those (out of support) nodes.
Perhaps in Revit 2024, tasks like creating section boxes or crop boxes with Dynamo are no longer supported. I will switch to C#. Thank you all very much!
Are there any alternative nodes for View3d.SetSectionBox and View.SetCropBox in the latest version, my friend?
It appears to be a Dynamo specific issue according to John’s comments.
If you read further down it appears everyone is praising the Zhukoven.com package (never seen it or tried it - over to you!).
If you do have luck with it, maybe report back to the thread here to help others in future with similar issues, and to reduce the commentary John needs to add to it in future - can tell and understand it must have been a frustrating bug to work through originally.
