Hi Folks,
I have some problems changing RVT models through Dynamo when the RVT files is on the Autodesk Cloud… My Dynamo graph is working fine when i work on RVT file when I have savded i locally on my machine… Anybody know something on this issue ?
Hello @Ranger1973 .not sure…what do you mean by changing model…could you show what you have tried and an example
Can I buy a vowel? What is the error in your graph? What are you trying to change? What does your graph do?
If your script does things which require a model to sit in your local server at the source (e.g. return the central model file path, or open/close models in bulk) then this wont work the same way as BIM360 which often needs forge/APE workflows.
If it is just general Revit model based tasks run within the model then most things should work, so as people said more information is needed.
