jj06jj
1
I defined it as a function, but the return value is different from the node above.
Please tell me the solution.
def CurveVertex(input)
curve = input;
param = [0, 1];
pt1 = Autodesk.Curve.PointAtParameter(curve, param<2>);
pt2 = DSCore.List.Flatten(pt1, -1);
pt3 = Point.PruneDuplicates(pt2, 0.001);
return = pt3;
Right now the code is working on a per-curve level. Try specifying the rank of the input:
def CurveVertex(input : var [])
You’ll also most likely need to iterate each curve and get its end points because the line:
will work in imperative execution mode if I remember correctly.
def CurveVertex (crv:var[]..[],prm:var[]..[])
pt1 = crv.PointAtParameter(prm<1>);
pt2 = List.Flatten(pt1,-1);
pt3 = Point.PruneDuplicates(pt2,0.001);
return pt3;
You’re referring to the use of Replication Guides and mean ‘will NOT’, I suppose
jj06jj
4
@Dimitar_Venkov @Vikram_Subbaiah
Resolved. Thank you!
If you know of any reference pages on how to fill out codeblock and function, please let me know!
jj06jj
6
