The focus is the codeblock starting with f; g; b; c; at the end.
Your main problem is that you have return = pt; at the end, outside of the Imperative statement. This is saying you want to make a variable return with the value pt, but you do not have a variable named pt so it is waiting for an input (check the input side of the node, it has an empty pt variable).
Your imperative statement already has return inside of it, so you do not need that line. Also d=[Imperative] can be just [Imperative].
The output you want to use is the arrow to the right of the [Imperative] line, that will contain the info you need.
What is the end goal or use case for this? You can probably just use a normal if statement with the boolTest? ifTrue : ifFalse; syntax. For here, it would be:
c < 13? b.Curve.PointAtParameter(b, 0.5) : Line.ByStartPointEndPoint(f, g);
But b.Curve.PointAtParameter is not a valid command, try Curve.PointAtParameter(b,0.5)
The goal of the codeblock is to create a condition when a crv is a certain length, it’ll create a line, or else it will just make a point at a parameter.
What is pt? It is not referenced anywhere else in the codeblock so there is no reason for it to be there. Just remove the line like my picture shows and it should work.
