I am having an issue with the Archi-Lab Override Fill Pattern in View node. I believe I have it wired up correctly, but obviously I don’t as I get the error message below. What am I doing wrong?
Ben
Ben
You have to feed the node a fill pattern element, not just a string with it’s name.
Using the element types like you have for the walls but using fill patterns, then filter for the element named “Solid fill”. Once you’ve isolated the element feed that in and the node should work as expected
Make sure list match: if you have 10 walls, then you must have 10 colors and 10 fill patterns.
Thanks to all for the responses and suggestions. It turned out I had the lacing incorrectly set to Shortest and once I changed it over to Longest everything worked fine
Is there any way to delete you desire solid fill when you have multiple solid fill.
waqar
