Greetings everyone !
Im trying to get all induces of a list of strings from another list of strings And i keep getting Warning : operation failed ! Is it because of the special characters ?
if you are seeking to find the index of the string within the list then you should use " List.Allindicesod"
the problem in your case that you should connect the code block list to the βitemβ input
Sorry for the missleading screenshot ! i did in fact conenct the list block to both indices of blocks and i still get the same warning !
do the both input is a strings ? the code block is clearly string but the other list from flatten, are the items strings ?
could you show what is the error on the list.allindices node ?
Both Inputs are strings and i get the same warning on both list.allindicesof and string.allindices of which is Warning : operation failed ! as shown on the screenshot below
I just figured out that the null values were whats wrong ! i just replaced the null valus by a β0β string and it worked
Thanks @khuzaimah.ElecEng for your help !
