Hi, I’m finding lots of nodes that are close, including List.AllIndicesOf, but not getting the results I’m after. I’m also newer to this forum so I apologize if this thread was already created.
I feed in the list and want to use a variable string for the search item. Then use the indices returned to grab values in another list. Is this the right approach?
Try using a number 1 instead of the string “1”.
Hi Jacob, I tried that with a code block and still no luck. The examples I’ve seen all appear to place a boolean in the item portion but that doesn’t make sense to me if I’m searching for a particular value.
I also tried the Number node with value of 1.000 and still no luck.
I’m so close but have an issue with variable type. I found another custom node(not sure which package) that works if I used a 2; in code block, no quotes. But I need it to pull from my parameter value instead.
Hi Jacob, just a follow-up that I was able to finally get it working by converting the string number to an integer. Thanks for pointing me in the right direction.
