TypeError: iteration over non-sequence of type NoneType
So, I’m getting this error in this python script which orients 3D views to vectors. I tried to iterate over the lists but keep getting this error.
#Import ToDSType(bool) extension method
#Import DocumentManager and TransactionManager
#Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import ReferencePointArray
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
views = tolist(UnwrapElement(IN[0]))
vectors = tolist(IN[1])
vt = []
for vector in vectors:
	v = vt.append(vector.ToRevitType())
app = uiapp.Application
#apply lineweight override to elements in an input list
for i in v:
	for view in views:
		view.OrientTo(i)
# "End" the transaction
OUT = doc.ActiveView
@theshysnail the Python output is feeding whatever active view you are in Revit, maybe someone else can help fetching the 3D views within Python after the orientation…, but as a quick response, you can try this:
#Import RevitAPI
view = UnwrapElement(IN[0])
vector = IN[1]
for vi, ve in zip(view, vector):
	v = ve.ToRevitType()
	vi.OrientTo(v)
OUT = 0#doc.ActiveView
here you heve to type
for i in vt:
The issue is that you’re setting v = vt.append(). Append already modifies the existing list, so you would just use vt in place of v.
