Problem import dynamo for Revit
Hi!
I have a problem when importing to revit: Warning: ImportInstance.ByGeometries operation failed. LibG does not upport non-ASCII directories. Rename your directory using only ASCII characters.
Does anyone know what it is?
At a guess it won’t accept something in your naming convention unless it simply contains numbers and letters (ie. The ‘e’ in your name wouldn’t be accepted).
I believe 0.8.0 fixed this issue and now allows any form of symbol - are you using 0.7.X ?
HI.
Needed to create a spline between two points and tangent to the straight? how can I do it?
Sending an image to explain.
Captura de ecrã 2015-05-14, às 10.37.00
I used 0.8.0
