In my custom node, implemented in c#, I performed some computation. To debug it, I print out some values to console. Under DynamoSandbox, choosing View/Console only showed the output from Dynamo kernel. What should I do to feed the console with custom data from node?
this isn’t currently possible, you can try requesting it on the GitHub issue page.
I think it’s a good idea as well, and in that case would get added to DynamoServices.dll
Thanks. I used DynamoLogger to log to file, but it’s not very much useful. I’ll submit the request to GitHub.
hmm, are you writing a nooemodel node or a zero touch node?
I’m writing a Zero Touch node. So far, it’s still learning by doing. Because I’m new to Dynamo and the visual programming concept.
