Hi, i have problem with Print.SetOptions from package Orchid. Sometimes this block works sometimes no. What’s the problem?
Have you checked if your printer is compatible with the paper size you’re feeding?
Yes, it’s compatible.
This example shows that we are working with graphs… data travels in a graph the fastest way it can. Since you try to use the same node twice may transaction cause you problems!
Why do you do what you are doing? Use only one node for the entire setting you want to create! …OR make your graph respect the needed transactions, add an “await” node to ensure one “SetOption” is finished before setting another!
