Print in Background
Hi all,
I try to print sone sheets in the background however I get an error with the plot PDF node.
I don’t know any phyton at all, so I have no idea what the problem is here.
Does someone has advice?
Thnx in advance!
Hi Daan,
I think you should use “Print PDF in Document” instead of “Print PDF”.
But in the end you also have to close the documents (you open in the background).
Maybe @Alban_de_Chasteigner can give you some more advise.
Kind regards,
Mark
Thank you MJB,
The Print in Document node and the fix of having the same number of Printsettings as Sheets made it work.
I still have to wait for it to finish the printing sadly. I was hoping I didn’t have to anymore…
Revit doesn’t really do anything in the background, and Eve things that are subscribed to the “Idling” event don’t matter when using Dynamo because that’s what it uses to complete the graph runs. Sadly as you pointed out, you’ll just have to wait.
