Hi forum, I found this post for rotating the fitting and its connected elements, but found that maybe our families don’t specify the primary connector in the order the script anticipates and it ends up rotating the selected pipe that is in alignment with the axis of the primary connector.
So I modified the script to rotate based on a connector I feed it through an input and it works except i can’t figure out how to get the connected element (pipe) to rotate with it as the dyn from the link does. Here’s my code, any suggestions? Note: still learning python and am not an engineer either, so could be missing something obvious:
clr.AddReference("RevitAPI")
import math
inn = [UnwrapElement(IN[0]), UnwrapElement(IN[1]), UnwrapElement(IN[2])]
conns = [0, 1]
def disconnect(curve):
connectors = curve.ConnectorManager.Connectors
for conn in connectors:
if conn.IsConnected:
for c in conn.AllRefs:
if conn.IsConnectedTo(c):
conns[0] = conn
conns[1] = c
conn.DisconnectFrom(c)
angle = (IN[3] * math.pi) / 180
# Get the connectors from the supplied element
connectors = inn[0].MEPModel.ConnectorManager.Connectors
connector = None
# Find the desired connector based on your criteria
# Add your logic to select the desired connector
if conn.Id == inn[2].Id:
connector = conn
break
if connector is not None:
loc = connector.Owner.Location
ductloc = inn[1].Location
# Extract the rotation axis from the supplied connector
rotation_axis = XYZ(connector.CoordinateSystem.BasisZ.X, connector.CoordinateSystem.BasisZ.Y, connector.CoordinateSystem.BasisZ.Z)
line = Autodesk.Revit.DB.Line.CreateUnbound(connector.Origin, rotation_axis)
disconnect(inn[1])
ductloc.Rotate(line, angle)
conns[0].ConnectTo(conns[1])
OUT = IN[0]
here’s the error:
here’s the result, the fitting rotates but connected pipe doesn’t:
Rotate PipeFitting and pipe.dyn (60.4 KB)
