Hai all,
i try to create pressure pipe run by polyline(used camber node). its getting an error.
please anyone can show a example for this node (Pressurepiperun.byobject).
Can you send a picture of the whole error message? The message will tell you which input type is incorrect.
Since the node is a Camber node, my guess would the PressureNetwork input for the node requires a Camber Pressure Network rather than a Pressure Network from the toolkit. I would try using a camber node to get the pressure network or convert it to a Camber object.
^ this! ![]()
Thank you so much
i found the error, i didn’t use camber node for pressure network.
thank you
