Dear all,
How to use the power function in code block? Kindly see attached.
Thanks.
Dear all,
Thanks.
Hey Chander,
try typing Math.Pow(x,y)
x being the number and y being the power.
Hello Chander Gupta,
All Math operations in Dynamo need to be used by writing Math. and method which you want to use.
Thanks,
Ritesh
Hi guys,
Thanks for your reply.
Math.Pow(x,y) works perfectly…
Chander.
It works just nicely…
Thanks Again
One suggestion, in your graph you have written X and Y in separate CBN and then connected to formula written in CBN.
Actually you dont have to create X and Y, you can directly pass output of Range expression (1…10…1 and 1…20…2) to your CBN where you have written Formula.
Keep using Dynamo, if stuck we are here to help you.
Thanks,
Ritesh
Oh yes…
x & y CBN is redundent.
Thanks.
Interesting !!
hi chander
Im was looking at your last image in this topic
Im working with points trough a spline and i trying to figure out how can i manage to control the distance between the points similar to what you got, in my case i want to change the Z axis,
Any ideas, Thanks man
