How to use Code Block in List.Map ?
Hi, everyone.
I am a new one in Dynamo.
This few days I am study about List, and List.Map is confusing me.
In the attatchment is the file about the question.
I want to add a number to all item in a List, and I use several way.
The builtin funformula, it works well.
The formula, it can only work for the first run time, and will not change for the next time when I change the formula.
When I use the code block, both I use the normal code block or self-define function, I can not get a result, they are all null.
I must have made some problems. Would you please help me to solve it, thank you very much.
question about list map
In the examples above you are trying to swat a fly with a hammer. Most of what you’re attempting can be achieved in a simple and direct manner.
Study the many definitions already posted on the forum for a better understanding of the List.Map node.
The f(x) port takes in an node (with one of the input ports left unwired). Code blocks are not a valid input.
Hi, dear VIKRAM SUBBAIAH,
Thank you very much for your replying and give me a very simple way.
Now I know that the code block can not be treated as a f(x).
I will study more in this forum for other knowledge.
I ask this question because I have ever learned some Lisp. In lisp Lambda like f(x) in Dynamo (but it can also a self-defined function), Mapcar likes List.Map, and they can combine together.
Thank you again!
