Hi everyone,
I have been working with the SteamNodes “PointCloud.GetPointsFromBoxSelection” node in Revit 2020 and it works great!
However, our models (and also corresponding Dynamo scripts) are preferably in Civil 3D, mainly because that eliminates the intermediate step of having to use Revit together with Dynamo and finding some creative solutions for exporting PolyLines.
So I was wondering if anyone had looked into how Civil 3D handles Point Clouds. And if not, where would be the best place for me to start looking.
The Node
Nested Python Code 1
#python nodes in dynamo 1.2
####BETA VERSION#####
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB.PointClouds import *
app = uiapp.Application
planes=[]
for i in IN[1]:
planes.append(UnwrapElement(i).ToPlane())
Iplanes=List[Autodesk.Revit.DB.Plane](planes)
pcf=PointCloudFilterFactory.CreateMultiPlaneFilter(planes)
averageDistance = IN[2]
numberOfPoints= IN[3]
points = UnwrapElement(IN[0]).GetPoints(pcf, averageDistance, numberOfPoints)
elements=[]
for p in points:
X=p.X
Y=p.Y
Z=p.Z
elements.append(Point.Create(XYZ(X,Y,Z)).ToProtoType(False))
OUT = elements
Nested Python Code 2
# Thanks for this code goes to:
# Copyright(c) 2016, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import Element wrapper extension methods
# Import RevitAPI
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
def ProcessList(_func, _list):
return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def Unwrap(item):
return UnwrapElement(item)
def GetTransform(e):
return e.GetTotalTransform().Origin.ToPoint()
def GetBasisX(e):
return e.GetTotalTransform().BasisX.ToPoint()
def GetBasisY(e):
return e.GetTotalTransform().BasisY.ToPoint()
def GetBasisZ(e):
return e.GetTotalTransform().BasisZ.ToPoint()
if isinstance(IN[0], list):
elements = ProcessList(Unwrap, IN[0])
elements = [Unwrap(IN[0])]
try:
errorReport = None
output = ProcessList(GetTransform, elements),ProcessList(GetBasisX, elements),ProcessList(GetBasisY, elements),ProcessList(GetBasisZ, elements)
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
#Assign your output to the OUT variable
if errorReport == None:
OUT = output
OUT = errorReport
Kind regards,
Daan
