I’m trying to create a surface fillet from Revit surfaces. The end result should look something similar to this.
However, I’m getting an error.
I also tried selecting the curves and filleting them with the intention to loft the two curves in Dynamo but also got an error. Obviously I can recreate all curves in Dynamo and use arcs instead of fillets, but I’m doing this in a iterative design process where it’s easier to draw the curves in Revit, select them in Dynamo and create the fillets there.
