Hello everybody
I have a problem want to ask. How to get the curve of the opening the wall, or when the door inserts into the wall as same in picture.
I have the exact same issue I’m struggling with now, anyone?
getting door opening base outline.dyn (45.7 KB)
This is quite a complicated task because you can’t get opening cut as an element itself. Thus in this method you need to select the wall and the door.
