Need help understanding polycurve fillet. I continue to update old VBA and VB routines to Dynamo, I found an issue with fillet polylines that I can’t seem to work out, sometimes it works and other times it doesn’t fillet the polyline, If I switch out the radius, it works and other times it doesn’t. I’ve tried the Boolean for right and left side, I tried no Boolean, it might be that I don’t know how the polycurve.fillet node works, to me I’m passing a radius valve to a defined polyline to fillet, if I have these nodes set correctly, it should work all the time. is there a better way to accomplish this task?
Did you try filleting the right side and then filleting the left side?
You’re creating two polylines with this - you want to create one.
Start by generating the PolyCurve via points.
Then wire that into a PolyCurve.Fillet node with the rightSide input set to ‘false’.
Then wire that into a second PolyCurve.Fillet node with the rightSide input set to ‘true’.
Then wire that into the PolyLineExtensions node.
Jacob,
Thank you, just like I said, I messed up my approach, it made sense to me to build the poly as I did, once again how you do things in dynamo make a big difference.
again, thank you for your time.
