Hi to all,
I’m trying to make a dynamo node script to create a multiple rows polar array.
I know there are several ways to create the first row, the problem is creating the other rows and set distance between rows and increasing elements for each row far away from the center.
Attached a manually created example.
Many thanks for any idea or solution.
Here’s two solutions, one using a designs script definition and one using nodes. Both allow the spacing between seats to flex so that you always have a seat at the middle of the curve and both ends. If you want Revit families at these locations look into your options for creating a family instance at each coordinate system.
I’ll try as soon as possible… I’ll let you know.
Many thanks.
how to deal with your code?
def polarArray(
origin: Point,
insideRadius: double,
rowCount: int,
rowSpacing: double,
startAngle: double,
endAngle: double,
normal: Vector,
seatSpacing: double
radii = insideRadius..#rowCount..rowSpacing;
arcs =
Arc.ByCenterPointRadiusAngle(
origin,
radii,
startAngle,
endAngle,
normal
len = arcs.Length;
firstHalf = 0..len/2..~seatSpacing;
secondHalf = len/2..len..~seatSpacing;
lengths =
List.UniqueItems(
List.Flatten(
List.Transpose(
firstHalf,
secondHalf
)@L3<1>,
-1
)@L2<1>
seatCoordinates =
Curve.CoordinateSystemAtSegmentLength(
arcs,
lengths
return seatCoordinates;
there is still an error
KR
Andreas
This isn’t required by core, but can be introduced by integrations (ie: Dynamo for Civil 3D, Dynamo for Revit) or by packages (ie: Orchid).
Not that I know of. I just utilize the forum for the stuff I post as this is already a full time hobby. ![]()
Anything which utilizes at parameter will fail to insert the extra seats in the subsequent rows. Everyone will look at the back of someone’s head if looking center stage, except for the first row.
hehe you are right…i need to go more out specially to stadiums ![]()
anyway when there is a goal everyone gets up and we can’t see anything and the glass of beer flies too
cordially
christian.stan
Sorry @Draxl_Andreas but unfortunately my dynamo knowledges are limitated. I’m new in coding with dynamo.
I’ve worked on @christian.stan example and found a way to add some nodes to simplify input data process and everything works fine, but for me this step is complicated to solve.
Instead of using family instance by point and then editing the rotation, utilize the FamilyInstance.ByCoordinateSystem, which will set the rotation as you go.
Looks like this:
Note I haven’t implemented the FamilyInstance.ByCoordinateSystem node or rotation of the coordinate systems to suit the family I used on the Design Script version.
DYN for testing: Seat Array.dyn (1.1 MB)
Edit: Forgot to post the results:
All of the scripts will need to be tailored to your chair family. In my example the chair is aligned to the origin. Your family appears to have the origin point in front or behind the chair by some distance. The graph will need to take this into account.
