Multiple familly array
Hi everyone!
I’m unsuccessfuly trying to creat a parametric array with multiple families with dynamo.
Capture
What I’m trying to do here is to have an alternated cleat array instead of the 3 cleats on the same point.
instead of :
123 123 123 123 123…
I’d like :
1 2 3 1 2…
The final aim is to play with the slider so I can change se distance between the different cleat in the architectural project.
Thank for your help,
what it looks like in 3D!
Capture%202
You can try it.
It’s probably possible, with proper lacing, to do it in 5 nodes, but for the life of me, it doesn’t cooperate this morning.Capture2Capture3
It’s cool. Without lacing.
Yeah!
the first one worked like a charm.
Thank you so much!
If a comment solved your problem, please mark it as solution so others who have your problem can easily find a solution.
