Point.prunduplicates not working as predicted
I try using the node point.pruneduplicates, but it doesn’t do what I want. Am I doing something wrong?
Hello…what will happend if you set prune duplicates tolerance to 0
same:
hmm… what happens if you disconnect the tolerance and just use standard tolerance, think is 0,001 :wink:
Hello
need to flatten your input list, if the input list has sublists, the process is defined for each sublist
yes, that works.
@jochem.kolthof
Maybe this topic also helps:
thanks for the information, that seems to be a better way indeed.
