Is there any way to create a non-hosted point load in Dynamo and assign coordinates to it?
I would like to create point loads in some elements, but the issue is that if I use hosted point load I only can create them at the beginning or end of the element.
Thanks in advance
Thanks, I will have to search how to do the script and insert it in Dynamo.
I hope it works
I hope you can follow up with your findings and result!
Try Element.Geometry. It’s sometimes a viable alternative.
However, recreating the program every time you need to place an element won’t be effective.
