I keep getting an error that says “Point object does not have attribute Coord”. It clearly does according to RevitAPI. What am I doing wrong here?
Can you show the error in the dynamo environment?
Looks like you are feeding a dynamo point into the Python node which uses the Revit API. You need to use a Revit based reference point for that to work.
ok, is there a way to convert a Dynamo point to a Revit point?
What is your end goal with the info you are after?
I was going to get the distances btw points in order to sort by proximity. I found a different approach altogether, but I’d still like to know how to convert the points, for future reference.
Ultimately, I’m am developing a tool to sort seats and rows (furniture and furniture systems) in spectator facilities using filled regions as demarkers.
