I’m trying to apply points on a surface by using the point at parameter node. How do I get the points to match the surface shape? <br style="color: #2e2e2e;" />
<br class="Apple-interchange-newline" />
Surface.PointAtParameter should have done the job, ideally. But it doesn’t, hasn’t been doing so for quite a while now
A crude workaround is to filter out the points that don’t lie on the surface using the Geometry.DoesIntersect
Kulkul
March 16, 2016, 12:30am
3
Hi Andre,
Make sure you turn off “Preview” for “SurfacePointAtParameter” & “FilterBoolMask” node.
Do we have away to center all the point with the room and omit the border lines
Look at the List.DropItems node.
Or a Surface.PerimeterCurves node, with a Geometry.DoesIntersect node and a Lost.FilterByBoolMask node.
Or a variety of other possible solutions.
