Placing PanelScheduleviews into existing sheets
Hi all,
I’m trying to place panelscheduleviews on existing sheets with the given script.
I retrieved the existing sheets and the panelscheduleviews. Also get the origin point in Dynamo with the node point.by coordinates, could I believe are the inputs that need to use the methods of create a ScheduleSheetInstance or viewport but not of them allows me to place panelscheduleview into sheets. I notice on Revit API we do have a class for Panelschedulesheetinstance but on their inputs do not have any arguments to include a location, so when I run the code, it just creates those but not placing on the sheet. I am using on Revit 2024 and Dynamo 2.19.
Here is the code to create Viewport.
clr.AddReference('RevitAPI')
sheets = [UnwrapElement(sheet) for sheet in IN[0]]
views = [UnwrapElement(view) for view in IN[1]]
points = IN[2]
viewports = []
# Start transaction
# Iterate through sheets, views, and points
for sheet, view, point in zip(sheets, views, points):
    try:
        # Check if view is a PanelScheduleView and can be added to the sheet
        if isinstance(view, View) and view.ViewType == ViewType.PanelSchedule:
            if Viewport.CanAddViewToSheet(doc, sheet.Id, view.Id):
                location = XYZ(point.X, point.Y, point.Z)
                # Create viewport
                viewport = Viewport.Create(doc, sheet.Id, view.Id, location)
                if viewport:
                    wviewport = viewport.ToDSType(False)
                    viewports.append(wviewport)
                    viewports.append("Failed to create viewport")
                viewports.append("Cannot add view to sheet")
            viewports.append("The view is not a PanelScheduleView")
    except Exception as e:
        viewports.append(f"Error creating viewport for sheet {sheet.Id} and view {view.Id}: {e}")
# Regenerate document once after all viewports are created
doc.Regenerate()
OUT = viewports
and here is for meths to create ScheduleSheetInstance
from Autodesk.Revit.DB.Electrical import *
app = uiapp.Application
points = IN[2]
scheduleview = []
# Start transaction
try:
        try:
                # Create viewschedule
                viewschd = ScheduleSheetInstance.Create(doc, sheet.Id, view.Id, location)
                if viewschd:
                    wviewschd = viewschd.ToDSType(False)
                    scheduleview.append(wviewschd)
                    scheduleview.append("Cannot add view to sheet")
                scheduleview.append("The view is not a PanelScheduleView or is an internal schedule")
            scheduleview.append(f"Error creating viewport for sheet {sheet.Id} and view {view.Id}: {e}")
finally:
    doc.Regenerate()
OUT = scheduleview
and finally, here is for the metod of PanelscheduleSheet Instance
# Get the current document
# Unwrap inputs
panel_schedule_views = UnwrapElement(IN[0])  # Second input: list of panel schedule view IDs
# Initialize lists to store the IDs and views
panel_schedule_view_ids = []
panel_schedule_views_ = []
# Loop through each Panel Schedule View and get its ID and View
for panel_sch_v in panel_schedule_views:
    panel_sch_v_id = panel_sch_v.Id
    panel_schedule_view_ids.append(panel_sch_v_id)
    panel_schedule_views_.append(panel_sch_v)
# Start a transaction
# Create multiple Panel Schedule Sheet instances
panel_schedule_sheets = []
for view_id, view_ in zip(panel_schedule_view_ids, panel_schedule_views_):
    panel_schedule_sheet = Electrical.PanelScheduleSheetInstance.Create(doc, view_id, view_)
    W_panel_schedule_sheet = panel_schedule_sheet.ToDSType(False)
    panel_schedule_sheets.append(W_panel_schedule_sheet)
# Commit the transaction
# Output the Panel Schedule Sheet instances
OUT = panel_schedule_sheets
The last one does not give me any errors, but I am still does not see the panelscheduleviews placing into the sheets.
Is there another method or there something that I am missing in order to achieve this. Any advice I really appreciate. Thanks.
Regards.
Schedules don’t use viewports.
Remarks
Schedule views are not handled by the Viewport class. Refer to [!:Autodesk::Revit::DB::ScheduleSheetInstance::Create()] for information about adding schedules to sheets.
The second error also tells you the issue with your method.
In addition you can use the Origin property
import sys
import System
#import Revit API
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
panelSchedule = UnwrapElement(IN[0])
sheet = UnwrapElement(IN[1])
title_block = FilteredElementCollector(doc, sheet.Id).OfCategory(BuiltInCategory.OST_TitleBlocks).FirstElement()
bbx_sheet = title_block.get_BoundingBox(sheet)
pt_Top_left = XYZ(bbx_sheet.Min.X, bbx_sheet.Max.Y, bbx_sheet.Min.Z)
panel_schedule_sheet = PanelScheduleSheetInstance.Create(doc, panelSchedule.Id, sheet)
panel_schedule_sheet.Origin = pt_Top_left
Thank you. Cyril, yes it works. Much really appreciate
Regards.
