Hi guys,
I am, as many here, a real Dynamo newbie, and am battling with setting values to revit from an excel file.
Scenario is:
I need to get an pre-filled excel file from our tech teams about where they need switches/servers installed into a rack/cabinet. I want to feed this into Revit/Dynamo and place the family instances at the correct OFFSET value, thereby setting the correct level in the server rack.
HOST for each Family = the Server Rack
Correct Height = “Offset Parameter”/45mm
I can place all instances manually, which works fine, but this is not using revit “smartly”. Hence i am trying to automate it via Dynamo.
i have attached:
- my excel template with sample data
- my DYN file
- and 1 picture of what i need to automate.
any help is greatly appreciated.
Set Rack-Height from Excel.dyn (36.0 KB)
Rack-Layout-Template.xlsx (9.3 KB)
Thanks !!
