Hi, i have a excel data that contain infromation about trees exsting along a road. The excel sheet consists of elevation (Z) , coordinates (X and Y) and the tree number §. I wanted to place assign block tree the given location ( as per teh excel) so far I have managed to do that but without the tree number. Tha means the trees are placed on the position but with out the name. Which command can i use to link the name from the excel . Thank you in advace.
How do you want the tree number to be assigned? Should it go in a block attribute, or just text in model space?
in block attribute
Use the BlockReference.SetAttributeByTag node and use the list of tree names as the input for the values.
Is it possible to share the script you used here?
