Place blocks in a list of points
Is there any way to place blocks in positions token from list of points ?
BlockReference.Create or BlockReference.ByCoordinateSystem
PlaceBlocksByPoints_2.dyn (30.2 KB)
Thanks so much, I believe it’s sufficient.
But I still have a query, if I wanna do it by BlockReference.ByCoordinateSystem node, what should be the input of the coordinate system ( dynamo script is attached)
The input should be a coordinate system. You may want to do some reading on the Primer if you’re unfamiliar.
https://primer.dynamobim.org/05_Geometry-for-Computational-Design/5-2_vectors.html
Will do some reading, appreciate if you can refer to more detailed resources
The first thing that comes to mind is the Alignment.CoordinateSystemByStationOffset, which is helpful for converting station + offset to a point.
In this case, I don’t have alignment to follow it’s coordination system unfortunately
An alignment isn’t required to produce a coordinate system for the BlockReference.ByCoordinateSystem node. You can use the CoordinateSystem.ByOrigin node to output a coordinate system with dynamo points as your input. This produces the same result as using the BlockReference.Create node
That’s pretty awesome, thanks mate
