I have a tree survey with the X and Y Coordinates of the trees. however the surveyor did not share the Z coordinate. We received a separate land survey using which we created the topo-surface in revit. I can use the cooridinates from excel via dynamo to place the trees in the correct location in plan (X-Y Axis). is there any way to get them to sit at the correct height as well based on the topo-surface we have generated.
RayBounce.ByOriginDirection Using the X,Y, and a Z that will always be above the surface (any Z above, not important) as the origin point. The direction will be straight down, or a Z = -1.
It has been a while so I might be wrong but I think max bounce should be set to 1 and view3D should just be any 3D view.
