Place groups att multiple levels
I need some help to solve a problme that i have with placing multiple groups at diffrent levels at the same time.
I have figured out how to place multiple groups at one level. I don´t want to place them by Z value. I want the groups (walls) to have the level as “home”.
I have used a modified PlaceGroupAtPoint to make it accept multiple groups.
Anton
Hmm…
I don’t think there is a Place Group method which uses Level…
http://www.revitapidocs.com/2018/586d4f2e-0985-2d0b-dbb7-ea6d2f704336.htm
How about if you place them by z offset, then set the Reference Level and Offset Parameters to what you want?
Ie. Place Group at Level 0, Offset 3m… Then Set Parameter Value By Name, Level 1, Offset 0m?
Hope that helps,
Mark
Sounds like a plan! i´ll try that!
