Kinda matters if your Family is either Face Based or not (for my or @sovitek approach).
yes @bvs1982 you are right ;)…in my test i just use users sample file and the family there was facebased…
Missed that . You were more sharp-eyed than me.
hhehe dont think so, just lucky and lazy
anyway personel i think it best with facebased here so their will follow if thing change …
Hi sovitek,
I really like your script, nice job!
How are you getting the non-rectangular ceiling to populate correctly? I have your script working and I am using face hosted air terminals, but the air terminal array is always rectangular.
Thank you,
Thatcher
Hi @Thatcher you could try set rotation
HI @sovitek,
This is useful, thank you. I meant how you were able to get the fixtures distributed only on the non-rectangular ceiling in your example, which is oriented along the XYZ axes, but has more than 4 sides.
Hi @Thatcher not really sure what you mean i dont have more than 4 sides in that example…i just sort these out with measure area…but its basic about get some vector from a line for , find the degree and rotate…
Hi @sovitek ,
I’m sorry for the confusion.
In your example from 23 Feb, the distribution of light fixtures does not appear outside of the non-rectangular ceiling. I replicated your script, but did I only get rectangular fixture arrays that may generate elements outside of the ceiling.
I suspect my version of the script does not match yours. How did you prevent the problem in my screengrab?
Thank you.
Thank you, thank you, @sovitek!
I got it working.
awesome thats great
I am having some trouble, your script is working well so I’d like modify it then get something.
1- Would like to center that point on my face of a space.
2- My fixture is looking up, if I’d like the fixture look down or get that face wich facing dow inside the space, I have tried modify Z value but, it’s not working proprely.
Thanks.
Hi @exmove069 im happy something could work…in other situation.create a new topic
Okay thanks.
