Dear Experts,
Is it possible to edit value of pipe “Segment Description” section:
Thanks.
an example with Python
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import specify namespace
from Autodesk.Revit.DB.Plumbing import *
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
dictPipeNameDescription = IN[0]
out = []
#pipesettings = PipeSettings.GetPipeSettings(doc)
segmentsPipeType = FilteredElementCollector(doc).OfClass(DB.Segment).ToElements()
for seg in segmentsPipeType:
description = dictPipeNameDescription.get(seg.Name)
if description is not None:
seg.Description = description
out.append(seg)
OUT = out
