Turn pipe segments into single pipe
Hi all,
Does any one have any suggestions about how to take the situation in the image below (Multiple pipe segments) and turn them into one single pipe? Preferably by reconnecting each one to its adjacent pipe?
Any help or advice would be greatly appreciated!
Hello
an example with Python and Revit API, at the input you need to make a list of lists of pipes group (same alignment) or one List of Pipe with same alignment
import sys
clr.AddReference('RevitAPI')
import System
def getConnectTo(connector):
    elemOwner = connector.Owner
    for refCon in connector.AllRefs:
        if  refCon.Owner.Id != elemOwner.Id and     refCon.ConnectorType == ConnectorType.End:
            return refCon
    return None
def getConnecDistant(group):
    lstCon = []
    for elem in group:
        if isinstance(elem, MEPCurve):
            connects = elem.ConnectorManager.Connectors
            connects = elem.MEPModel.ConnectorManager.Connectors
        lstCon.extend(connects)
    pairLst = [[x, y] for x in lstCon for y in lstCon ]
    pairLst.sort(key = lambda x : x[0].Origin.DistanceTo(x[1].Origin))
    return  pairLst[-1]
toGroup = lambda x : x if hasattr(x[0] , '__iter__') else [x]
lstGoupPipe = toGroup(UnwrapElement(IN[0]))
for group in lstGoupPipe:
    con2DistanA, con2DistanB = getConnecDistant(group)
    pipeA = con2DistanA.Owner
    #prepare list to delete
    lstgroupId = List[ElementId]([x.Id for x in group if x.Id != pipeA.Id])
    #get connector to move
    seconConPipeA = [ x for x in pipeA.ConnectorManager.Connectors if x.Id !=  con2DistanA.Id][0]
    conToConnect = getConnectTo(con2DistanB)
    if conToConnect:
        seconConPipeA.ConnectTo(conToConnect)
        seconConPipeA.Origin = conToConnect.Origin
        seconConPipeA.Origin = con2DistanB.Origin
    doc.Delete(lstgroupId)
Wow, thank you C.poupin, works perfectly!
Really wish I knew Python like this…
Thanks again for your help, I really appreciate this!
