I’ve just completed Gerard Nicholson’s Gherkin Dynamo Graph tutorial (which I recommend). See links below and graph attached.
https://www.autodesk.com/autodesk-university/class/Gherkin-Cloud-Fusion-360-Dynamo-Revit-Workflow-2018Gherkin_2019.02.21.dyn (50.9 KB)
I’m now wondering how the panels can be adapted to take on a Phyllotactic pattern rather than the diamond pattern in which all points are clearly horizontally and vertically aligned/ stacked. In other words, I’m trying to modify the graph to look more like a pineapple or pinecone, following the fibonacci series with no clear vertical or horizontal datums.
I’m starting with the dynamo primer exercise/graph on Phyllotaxis and hoping to apply it to a 3D lofted surface rather than the single flat plane in the original exercise. I would greatly appreciate any initial guidance/links anyone can provide and I will keep posting my progress on a working graph in the comments below. Thanks!
http://primer.dynamobim.org/04_The-Building-Blocks-of-Programs/4-2_math.html
Building Blocks of Programs - Math.dyn (55.9 KB)
