I’m having a problem whenever i use the Phases node.
Dynamo crashes and returns with this error :
This the content of the “Details”
The type initializer for ‘Orchid.RevitProject.Document’ threw an exception.
at Orchid.RevitProject.Document.get_Current()
at Orchid.E.RevitProject.Project.Phase.PopulateItemsCore(String currentSelection)
at CoreNodeModels.DSDropDownBase.PopulateItems()
at CoreNodeModels.DSDropDownBase…ctor(String outputName)
at Orchid.E.RevitProject.Project.Phase…ctor()
at lambda_method(Closure )
at Dynamo.Wpf.ViewModels.NodeSearchElementViewModel.OnClicked()
at Dynamo.UI.Controls.InCanvasSearchControl.ExecuteSearchElement(ListBoxItem listBoxItem)
at Dynamo.UI.Controls.InCanvasSearchControl.OnMouseLeftButtonUp(Object sender, MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnPreviewMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
I am using revit 2017 :
17.0.1169.0
20190508_0315(x64)
2017.2.5
Dynamo Core 1.3.1.1736
Dynamo Revit 1.3.1.1736
