Pdf files
How to add a pdf file to revit .Are there dynamo script to do it ?
Bonjour est il possible d ajouter un fichier pdf ou word dans revit ou via dynamo car je dois integrer des conventions ou contrats dans revit et pouvoir les voir aussi dans un viewer
Merci
Hi @bamba2030,
You can link a PDF file in Revit with Revit 2020.
I didn’t check if this is in the Revit 2020 API.
Topic Translation :
Hello is it possible to add a pdf or word in revit or via dynamo because I have to integrate conventions or contracts in revit and can see them also in a viewer
Thank you
