Paste the parameters automatic way
We have the parameter values in Excel. It’s Placed in Columns. These values need to pasted in the specific elements in Revit. This is huge time consuming work. We are trying to reduce the time by do this work using the Dynamo.
We are doing this manually with two screens.
Actually we are try to do copy the values from Excel and then switch to Revit and Select the element. After selecting the element those values need to be feed automatically.in the Parameters.
Pls help in this regards
STM
Welcome back to the forums! Please take a look at the link below:.
In the meantime, you’ll want to look at nodes relating to reading xlsx/csv files. Both can be done with the out-of-the-box Dynamo nodes.
Is it a good assumption that you’ll have many rows of data? Are you still looking to select the element in Revit each and every time, or are you trying to automate that as well?
If you have any sample files or sketches of what you have attempted in Dynamo so far, please post them as a starting point.
