Parameters not used
Edited by Moderator. See below the line for original post.
Hello everyone ,
I am in the process of updating the shared settings of my files.
I want to delete all the parameters not specified in the project. (I do not have the same list of parameters from one project to another)
Do you have a dynamo solution that allows me to do this in one go?
Thank you in advance for your feedback.
Original post below
Bonjour à tous ,
je suis en train de remettre à jour les paramètres partagé de mes fichiers .
je veux supprimer l’ensemble des paramètres non renseigné dans le projet .( je n’est pas la même liste des paramètres d’un projet à un autres)
Auriez-vous une solution dynamo me permettant de faire ça d’un seul coup?
merci d’avance pour votre retour .
Welcome to the forum @oumaima.bensassi-ext. the forum language is English which is a requirement for search to work. Going forward please use a translation service of your choice to post in English, keeping the original post if desired as well as I did in the edit of your post above (this will help should we ever be able to make multiple languages work).
Hi @oumaima.bensassi-ext
See if this article can help you.
