ParameterbyName
Maybe it’s because it’s Wednesday but I’m sure I’m missing something basic here - I’m trying to get the ‘Type Mark’ parameter name to feed into the View Filter nodes but using Parameter.ParmeterByName I can only get instance parameters - can anyone point me in the right direction?
Cheers
K.
What does the “Type Mark” Say in Revit?
To get Type Parameters look here:
Hey Keith,
Sometimes, Dynamo fails to load some of the newly created parameters. It has happened with me a few times
and right now, it has happened with you too.
I would advise you to create an “Element.Parameters” node and check if your Parameter is listed there.
If not, then it is an interim problem and please send it as a bug issue to Autodesk. If you need something, please tell me. Happy to help.
Regards,
Nainoor.
That was it - many thanks.
