Hi everyone,
I have to copy values of a parameter named “Indicateur partie privative ; partie commune”.
The problem is the caracter “;” inside the chainstring that is not supported by the code block. How can I override this problem ?
Thanks for your answers !
staylor
2
Use string input instead of a code block. You won’t need the quotations then either.
If you insist on a code block …
Hi, weird comes from the dynamo version maybe
cordially
christian.stan
Thanks a lot for your reactivity @Vikram_Subbaiah @staylor and @christian.stan. It seemed simple especially with the string module. Perfect !
