Hi, I am trying to get the names and values of the element parameters respectively, but for some parameters like Type Id in the picture, the value of Type Id obtained by Parameter.Value node is not the actual value, it should be 788923 rather than “Family Type: Beam-600×760mm”, right? Why it is the case and how to get the correct parameter values? Thanks!
export all element param.dyn (26.8 KB)
Model: model.rvt - Google Drive
