Panel Cut Optimization
Is there a way to introduce a panel cut optimization in Revit?
E.G, for wall cladding, you enter the standard panel formats which are available, and while manipulating the geometry, you immediately get the numbers of panels you need.
The purpose is obviously to generate as less waste as possible.
The next step might be that you get the division of the geometry as a result of the most effective cut optimization.
We have Optimization Software
-But this is a standalone software.
-This is for nested element, for a CNC processing center
(not suited for a Panel sawing machine which divides the element in straight lines)
Can I find this functionality in Dynamo?
Kind regards,
Willem
Yes - this sort of a variation of a bin packing algorithm. There are a few examples in the forum, one specifically related to beam lengths.
